rgcdfw
Jun 04, 2025Aspirant
Windows 11 slow download speeds
Is anyone experiencing the same: I have three laptops all fully updated with the latest version of Windows 11, one is a work laptop and the other two are personal. Each windows 11 device is conn...
ageinghack
Jun 05, 2025Tutor
I see that you have already talked to Microsoft, did that go into public/private network settings?
Tried the usual trick of getting the laptops to forget the wifi connection and setting it up from scratch?
What router/gateway/optical network termination (ONT) connects you to the Internet?
Does the same thing when you use the laptops away from the RS100?
Sounds like this happened recently. Anything changed? Checked that it wasn't the usual monthly Windows update that killed it?
