LT26
Feb 03, 2026Aspirant
WPA2 on 2.4ghz overriding WPA3 on 5ghz band
I have a Wifi7 RS140 router. I've have some older smart plugs that only work with WPA2 security. No problem I just use the 2.4 band for those using WPA2. I have set the 5ghz band to WPA3 security for...
Feb 03, 2026Guru - Experienced User
Max sure you using mixed security mode for 2.4Ghz. WPA2 and WPA3 so IoT devices can still connect while your phone connects at 5Ghz with WPA3 if the phone supports WPA3. Most newer generation phones do. Most IoT devices only support WPA2. Can disable Smart Connect to tests all this as well, then re-enabled it.
LT26
Hi. I have tried mixed wpa2 and wpa3 protocol, but as another community user stated it does not work with the older wpa2 only devices. Maybe it works with some, but not on my (or his) plugs. Thanks for the suggestion though.
