LT26
Feb 03, 2026Aspirant
WPA2 on 2.4ghz overriding WPA3 on 5ghz band
I have a Wifi7 RS140 router. I've have some older smart plugs that only work with WPA2 security. No problem I just use the 2.4 band for those using WPA2. I have set the 5ghz band to WPA3 security for...
LT26
Thanks everybody for your quick responses and suggestions. Since 5G wifi7 speeds on my android phone are more important than outdated smart plugs, for $25 for a pack of four I just decided to buy new smart plugs that support WPA3 security.
