brandeau_anthon's avatar
Mar 13, 2023
wax218 SSID CONFIG-ONLY unable to connect to then interface
hello,
I have a pc which is connected to internet via a cable.
I connect to ssid CONFIG-ONLY of my wax218...
i could ping my wax218...
but when i try to access ti http://192.168.100.1
my navigator displayed
You have arrived at this page, mostly likely because you are currently not connected to your NETGEAR Business WiFi products. To access aplogin.com, aplogin.net, routerlogin.com or routerlogin.net, your device must be connected to your Router or Access Point’s WiFi network.
what is the solution?
thanks
anthony
1 Reply
  • Edwin_A's avatar
    Edwin_A
    NETGEAR Moderator
    Hello @ Bernadeau,
    And welcome to the NETGEAR Community! 🙂
    A few questions to begin:
    - How did you get the ip address?
    Did you get it from devices connected to your router/ switch?
    Or from a generic ip scanner as the advanced ip scanner.
    - Could you, please, give the device a reset?
    Let us know how it goes.
    Have a lovely day,
    Edwin A
    Netgear Team
