PatrickBuys
Sep 20, 2020Aspirant
airprint does not work using GS116Ev2
What am I doing wrong? When connecting the printer (Brother MFC-J5320DW) to the router using the switch printing from an Iphone or Ipad airprint does not work. When connecting the printer directly ...
MichelvanEunen
Sep 24, 2020Aspirant
Your switch is a 'Green Switch'. Means thats it has a advanced energy managament onboard (IEEE). The Orbi routers/satelliets do not work wel with this protocol. In fact not at all...
Or keep the printer connected to the router, or buy a cheap non managed/IEEE switch, or try do disable this 'green' features in the switch.
- PatrickBuysSep 28, 2020Aspirant
Thanks fort your reply.
I checked the setting for Power Saving and it was already disabled.
For your suggestion to insert a simple switch in the network to get this working is nog realy an option as I bought these switches to get iTV with CanalDigital working. This was advised by my ISP because they believe Netgear IGMP snooping works best with my router.
kind regards,
Patrick
