thierman's avatar
thierman
Can't get help unless I repost on the same topic ReadyCloud not working with Version 2.0.1
    I posted this under another thread but have been told to repost this in it's own thread, even though it appears to be the same issue. Just different symptoms.   For about a couple of week...
  • StephenB's avatar
    May 07, 2018
    Retired_Member wrote:
    the temporary workaround is to enable HTTP admin in service setting.
    Don't do that if you have port 80 forwarded to the NAS, as that creates a significant security risk.  Live without ReadyCloud instead.
ProSupport for Business
