thierman
May 04, 2018Aspirant
Can't get help unless I repost on the same topic ReadyCloud not working with Version 2.0.1
I posted this under another thread but have been told to repost this in it's own thread, even though it appears to be the same issue. Just different symptoms.
For about a couple of week...
- May 07, 2018
Retired_Member wrote:
the temporary workaround is to enable HTTP admin in service setting.
Don't do that if you have port 80 forwarded to the NAS, as that creates a significant security risk. Live without ReadyCloud instead.
Anonymous
May 07, 2018Hello thierman
ReadyCLOUD dev found that if user disabled HTTP admin in service setting page,then it will cause "Network error occured" issue,they will release a new app version in the near future to fix this issue,now the temporary workaround is to enable HTTP admin in service setting.
May 07, 2018Guru - Experienced User
- thiermanMay 07, 2018Aspirant
Thanks guys,
I'll keep an eye out for when this is fixed so I can turn off HTTP admin.
