gerak
Oct 20, 2021Aspirant
Can't login to Readycloud with Chrome
I cannot login to Readycloud nor netgear page with my account in Chrome on desktop. The error is Request time out. However I am able to login through Chrome on my phone or with Firefox on by deskt...
- Oct 22, 2021
Just updated my Java and the problem is fixed.
Oct 20, 2021Guru - Experienced User
Is "netgear page" the ReadyNAS web ui? If not, then can you explain what it is?
gerak
Oct 21, 2021Aspirant
I mean the Netgear Community page.
I can login with Firefox and Chrome on Android, but not with Chrome on my Desktop, which is my default browser.
It is the same when I try to login to ReadyCloud.
- StephenBOct 21, 2021Guru - Experienced User
I can log into both sites using Chrome from my Win10 desktop.
Have you tried
- other browsers on the desktop?
- using an incognito window?
- clearing cookies/cache?
- disabling internet security software (Kaspersky, Avast, etc).
- SandsharkOct 21, 2021Sensei
What error message are you getting? Have you changed your password and Chrome might have the old one saved?
- gerakOct 22, 2021Aspirant
Have you tried
- other browsers on the desktop? - Yes, it works with Firefox.
- using an incognito window? - Yes, it works with Netgear community, but Readycloud goes into infinate loop of loading process
- clearing cookies/cache? - I have tried, but it doesnt change anything.
- disabling internet security software (Kaspersky, Avast, etc). - No change after that.
I have also tried from 2 different computers - PC and laptop and it is the same when I'm logged into my Google account.
I can use Firefox for the time being but it is a strange problem and I can't find any reason for it.
A month ago I had no similar issues.
- StephenBOct 22, 2021Guru - Experienced User
gerak wrote: using an incognito window? - Yes, it works with Netgear community, but Readycloud goes into infinate loop of loading processI see that infinite loop also (and I can log into ReadyCloud with Chrome).
Have you tried removing any saved passwords for the two sites?
Does signing out of your google account make any difference?
