tomiaurednik
Jun 22, 2016Tutor
copy dir/files from NAS to USB; NAS backup , cannot create directories
Hi, RN104: 2 HDD Raid 1, v6.5 I would like to copy data (files, directories) from NAS to USB externa drive without using any computer. USB Flash drive connected directly to NAS. How can I do...
tomiaurednik
Jun 24, 2016Tutor
HI,
I can w/r to USB from PC (connect USB directly to PC).
It's NTFS file system
tomiaurednik
Jun 24, 2016Tutor
It seems that the problems ware, because it was not a safe remove from NAS. I Repaired on windows, now works.
- BrianL2Jun 28, 2016NETGEAR Employee Retired
Hi tomiaurednik,
Great! I was about to ask you to do that that if my previous suggestion would not work. You may now tag this thread closed by clicking the "Accept as Solution" button in one of the responses that you received. We also look forward to hearing more from you and be a helpful resource to the community.
Kind regards,
BrianL
NETGEAR Community Team
