utelme's avatar
utelme
Creating A New Volume
Solved: Creating a New Volume unable to click nexted after Naming volume and Selecting the RAID Level   Hi,   I was attempting to create a new Volume on my Netgear ReasyNAS 31600 model NAS I ...
  • Marc_V's avatar
    Jan 08, 2019
    Hi utelme
    When entering a volume name, the volume must not use the same name as a folder in the root folder system. The volume names home , apps , and job_ are reserved and cannot be used. Using spaces might also be included that is why it is not letting you create the volume.
    I agree that getting a popup message would be best to let the user know that there's an error or a mismatch with the condition in the name.
    Regards
ProSupport for Business
