utelme
Jan 04, 2019Aspirant
Creating A New Volume
Solved: Creating a New Volume unable to click nexted after Naming volume and Selecting the RAID Level
Hi,
I was attempting to create a new Volume on my Netgear ReasyNAS 31600 model NAS I ...
- Jan 08, 2019
Hi utelme
When entering a volume name, the volume must not use the same name as a folder in the root folder system. The volume names home , apps , and job_ are reserved and cannot be used. Using spaces might also be included that is why it is not letting you create the volume.
I agree that getting a popup message would be best to let the user know that there's an error or a mismatch with the condition in the name.
Regards
Marc_V
Jan 08, 2019NETGEAR Employee Retired
Hi utelme
Regards
Jan 08, 2019Guru - Experienced User
Marc_V wrote:When entering a volume name, the volume must not use the same name as a folder in the root folder system.
It's also a bad idea to use a volume name that matches a share name or a user name. The system will let you do it (at least the share name), but it will cause issues when you access the NAS with File Explorer using admin credentials.
