Retired_Member
Dec 11, 2018Delete Account
How do I delete this account? I ended up with a separate myNetgear account and I want to delete this old account.
- Retired_MemberDec 12, 2018
Retired_Member
Dec 11, 2018Hi Retired_Member, you could do that while being logged in to this account. Go to your profile by clicking your name left to your logo/avatar. Use /My Settings/Close Account.
Kind regards
Retired_Member
Dec 11, 2018Will that delete my Netgear account also? It sounds like it is just for the community account.
- Retired_MemberDec 11, 2018
Hi Retired_Member, when you ask "How to delete this account?" in a post on this community for me you clearly refer to the account you are using at the moment. This (community) account will be deleted, though.
I have no idea what will happen to your netgear account then.
Perhaps one of the NETGEAR mods have a suggestion.
- Retired_MemberDec 11, 2018Sorry I wasn't clear. I want to delete all Netgear accounts associated with a particular email address.
- Marc_VDec 12, 2018NETGEAR Employee Retired
Hi Retired_Member
Welcome to the Community!
I will send you a PM for the information needed so we can check it and process your request.
Regards
- Aug 04, 2022Retired_Member
- May 30, 2020Retired_Member
- Feb 17, 2021Retired_Member
- Sep 11, 2016Retired_Member
- Aug 29, 2020Retired_Member
