cbrinkley71
Aug 24, 2016Tutor
downloading documents from readycloud
Since the last firmware update to 6.5.1 any .pdf, .doc, or .xls file I try to download remotely (pc, or mobile) is a corrupt file with a file size of 1k. I kept thinking Netgear would figure this ou...
bcannon89
Aug 25, 2016Aspirant
I'm having the same issue using the 204. All files are 1kb and I can't open any of them when I download them. I also tried emailing them to myself and creating a download link and came to the same result. Very disappointing to say the least.
- StephenBAug 25, 2016Guru - Experienced User
Just want to add that some other users have also had this problem: https://community.netgear.com/t5/ReadyCLOUD/Downloading-pdf-files-from-ReadyCloud/td-p/969238
- bcannon89Aug 25, 2016Aspirant
I saw that thread eariler. The files I'm trying to download are in the root shares folder i.e. (\ReadyCLOUD\NASname\data\Documents). They file name is as generic as it can be. Specifically it's labeled "503.pdf". It's a 700kb file and it only downloads as a 1kb file that is corrupt or something. Tried opening multiple file types, naming conventions, in multiple locations and they all have this issue. So nothing in that thread is useful to our issue.
The only real difference is that they found that shortening the path name resolved their problem - which doesn't work for you.
You could still pm JohnRo and see if he is willing to help diagnose.
