Roger310
Dec 27, 2018Aspirant
export of snapshots
would like to automaticly export snapshots to my google drive account.
I have already setup the snapshot as weekly and made them visible.
I created the job using the google drive featue o...
Roger310
That's not the issue at this point. But yes I do only have the 15G with google at this point.
I have 64G of information on the Nas drive.
Why is the snapshot also 64G? It seems to me that it should be much smaller as its supposed to be an image file correct?
Dec 28, 2018Guru - Experienced User
BTRFS snapshots aren't image files. Each snapshot has the full contents of the shares when they were taken, so if you have 10 snapshots, backing them up to other storage would take 10x the room it takes to back up the share.
The trick is that data blocks that haven't changed from the original share are held in common, so only the changes take space on the disk.
This post might help clarify how they work: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-312-Need-Help-Understanding-Snapshots/m-p/936586#M171850
- Roger310Dec 28, 2018AspirantThank you! That explains what I'm seeing.
So my next question than is there a means of creating an image file to restore from?
I'm not sure that it needed as the NAS is running g in raid 1. But I never trust a single device.- StephenBDec 28, 2018Guru - Experienced User
You should certainly have a backup of the NAS, since RAID isn't enough to keep your data safe.
The closest thing to an "Image backup" is ReadyDR, which is only available if you are backing up to another ReadyNAS. Of course you can do incremental backups to a USB disk or another network device, or you can back up to cloud storage. However those options won't let you back up the snapshots (or more precisely, the storage cost of backing up the snapshots would be prohibitive).
My own main backup device is another ReadyNAS, though I use daily incremental rsync backups (not ReadyDR). Snapshots are enabled on the destination NAS, so I can get most of the older versions (though the snapshots don't match the primary ReadyNAS). I use rsync because I want the backup to be immediately available (ReadyDR backups need to be restored in order to access the contents).
