dmachr2
Aug 26, 2020Aspirant
Formerly "Volume Degraded" drive is now fine after recovery
One of my drives recently said "volume degraded", (Western Digital Red, WD40EFRX) but then after a few days of automatic data recovery, the disk reads as healthy. I had started an RMA with WD, but sh...
Aug 26, 2020Guru - Experienced User
Have you looked at the smart stats?
Using the green icons in RAIDar or the web ui isn't a good way to assess disk health.
- dmachr2Aug 26, 2020Aspirant
OH good call. Just checked the logs... opened up "status" file. Is this what you mean? Below is some recent logs from it
[20/08/23 11:24:43 EDT] notice:volume:LOGMSG_RESILVERCOMPLETE_DEGRADED_VOLUME The resync operation finished on volume data. However, the volume is still degraded.
[20/08/23 11:25:45 EDT] notice:disk:LOGMSG_ADD_DISK Disk Model:WDC WD40EFRX-68N32N0 Serial:WD-WCC7K1SFPUH7 was added to Channel 1 of the head unit.
[20/08/23 11:26:00 EDT] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[20/08/24 01:00:16 EDT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[20/08/24 11:50:24 EDT] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[20/08/24 11:50:27 EDT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[20/08/24 11:50:27 EDT] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[20/08/24 11:50:27 EDT] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[20/08/24 11:50:51 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/08/25 01:00:44 EDT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[20/08/26 01:00:36 EDT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[20/08/26 07:59:41 EDT] notice:volume:LOGMSG_RESILVERCOMPLETE_VOLUME Volume data is resynced.
[20/08/26 07:59:42 EDT] notice:volume:LOGMSG_HEALTH_VOLUME Volume data health changed from Degraded to Redundant.
[20/08/26 07:59:43 EDT] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel 1 (Internal) changed state from RESYNC to ONLINE.- JohnCM_SAug 26, 2020NETGEAR Employee Retired
Hi dmachr2,
You may open the disk_info.log to check the SMART stats of the disks.
Regards,- dmachr2Aug 26, 2020Aspirant
This is what appears after the disk that was causing issues..doesn't seem like anything is wrong now?
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 37
Start/Stop Count: 7339
Power-On Hours: 9687
Power Cycle Count: 19
Load Cycle Count: 7327
