dmachr2
Aug 26, 2020Aspirant
Formerly "Volume Degraded" drive is now fine after recovery
One of my drives recently said "volume degraded", (Western Digital Red, WD40EFRX) but then after a few days of automatic data recovery, the disk reads as healthy. I had started an RMA with WD, but sh...
dmachr2
OH good call. Just checked the logs... opened up "status" file. Is this what you mean? Below is some recent logs from it
[20/08/23 11:24:43 EDT] notice:volume:LOGMSG_RESILVERCOMPLETE_DEGRADED_VOLUME The resync operation finished on volume data. However, the volume is still degraded.
[20/08/23 11:25:45 EDT] notice:disk:LOGMSG_ADD_DISK Disk Model:WDC WD40EFRX-68N32N0 Serial:WD-WCC7K1SFPUH7 was added to Channel 1 of the head unit.
[20/08/23 11:26:00 EDT] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[20/08/24 01:00:16 EDT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[20/08/24 11:50:24 EDT] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[20/08/24 11:50:27 EDT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[20/08/24 11:50:27 EDT] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[20/08/24 11:50:27 EDT] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[20/08/24 11:50:51 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/08/25 01:00:44 EDT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[20/08/26 01:00:36 EDT] warning:volume:LOGMSG_HEALTH_VOLUME_WARN Volume data is Degraded.
[20/08/26 07:59:41 EDT] notice:volume:LOGMSG_RESILVERCOMPLETE_VOLUME Volume data is resynced.
[20/08/26 07:59:42 EDT] notice:volume:LOGMSG_HEALTH_VOLUME Volume data health changed from Degraded to Redundant.
[20/08/26 07:59:43 EDT] notice:disk:LOGMSG_ZFS_DISK_STATUS_CHANGED Disk in channel 1 (Internal) changed state from RESYNC to ONLINE.
JohnCM_S
Aug 26, 2020NETGEAR Employee Retired
Hi dmachr2,
You may open the disk_info.log to check the SMART stats of the disks.
- dmachr2Aug 26, 2020Aspirant
This is what appears after the disk that was causing issues..doesn't seem like anything is wrong now?
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 37
Start/Stop Count: 7339
Power-On Hours: 9687
Power Cycle Count: 19
Load Cycle Count: 7327- JohnCM_SAug 26, 2020NETGEAR Employee Retired
Hi dmachr2,
Can you post the complete disk_info.log? (Please omit the serial numbers of the hard drives.)
You may also send me the complete system logs of your NAS so we can check it. You may upload it to a file-sharing site then send me the download via private message.
Hi dmachr2,
I looked in the logs and it appears that your volume is not degraded anymore. All the disks are healthy when I checked the disk_info.log. It just has degraded status when disk 1 is still resyncing. Your volume has redundancy now after it finished resyncing.
