dmachr2
Aug 26, 2020Aspirant
Formerly "Volume Degraded" drive is now fine after recovery
One of my drives recently said "volume degraded", (Western Digital Red, WD40EFRX) but then after a few days of automatic data recovery, the disk reads as healthy. I had started an RMA with WD, but sh...
JohnCM_S
Aug 26, 2020NETGEAR Employee Retired
Hi dmachr2,
I looked in the logs and it appears that your volume is not degraded anymore. All the disks are healthy when I checked the disk_info.log. It just has degraded status when disk 1 is still resyncing. Your volume has redundancy now after it finished resyncing.
[20/08/26 07:59:42 EDT] notice:volume:LOGMSG_HEALTH_VOLUME Volume data health changed from Degraded to Redundant.
dmachr2
Any idea what could have caused it? Would it have been the readymade itself? Would it say that the volume is degraded if it would’ve lost contact somehow? (Maybe the connection isn’t great??)
- StephenBAug 27, 2020Guru - Experienced User
Do you see anything in your logs before 20/08/23 11:24:43?
There are a couple of questions here - the big one is what triggered the resilvering? Normally that would either be a result of a scrub (run from volume settings wheel), or inserting a new drive.
Though if you didn't shut down the NAS cleanly (for instance if there was a power failure or you pulled the plug), then there might have been some cached writes that were lost. That can also trigger a resilvering (usually called a resync in the web ui).
dmachr2 wrote:
Would it say that the volume is degraded if it would’ve lost contact somehow? (Maybe the connection isn’t great??)The relevant "connections" are the SATA and power connections to the disk drives. If the drive isn't well seated, then that could have caused it. You could power down the NAS, and then pull each drive and reinsert it. But don't do that with the NAS running.
Another possibility is that the drive was slow to start up when the system was booted, and came on-line after the volume was mounted. Or a command timeout or some other error might have brought the drive off-line.
Of course the chassis could be at fault (the SATA backplane or the controller).
- dmachr2Aug 27, 2020Aspirant
StephenB this is what the rest of the log looks like. i've only had it operational for about a year or so:
[19/07/18 06:09:02 PDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/07/18 06:09:01 PDT] notice:system:LOGMSG_FIRMWARE_UPGRADED Firmware was upgraded to 6.4.0.
[19/07/18 06:09:34 PDT] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[19/07/18 06:15:52 PDT] notice:system:LOGMSG_MODIFY_HOSTNAME Host name was changed to .
[19/07/18 09:34:36 EDT] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[19/07/18 09:38:19 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/07/18 09:38:18 EDT] notice:system:LOGMSG_FIRMWARE_UPGRADED Firmware was upgraded to 6.5.2.
[19/07/18 09:38:29 EDT] alert:account:LOGMSG_ACCOUNT_USERNAME_CHANGED User was renamed to .
[19/07/18 09:38:51 EDT] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[19/07/19 11:56:19 EDT] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[19/07/19 11:56:24 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/07/19 11:56:56 EDT] notice:volume:LOGMSG_RESILVERSTARTED_VOLUME Resyncing started for Volume data.
[19/07/22 02:05:44 EDT] notice:volume:LOGMSG_RESILVERCOMPLETE_VOLUME Volume data is resynced.
[19/07/22 14:59:12 EDT] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[19/07/22 15:03:35 EDT] notice:system:LOGMSG_FIRMWARE_UPGRADED Firmware was upgraded to 6.10.1.
[19/07/22 15:03:36 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/07/23 09:01:39 EDT] info:system:LOGMSG_SPINDOWN_ENABLE Automatic disk spin-down enabled.
[19/07/23 09:03:45 EDT] info:system:LOGMSG_PROTOCOL_DISABLED Service protocol AFP is disabled.
[19/07/24 08:11:28 EDT] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[19/07/24 08:11:54 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/07/24 08:21:43 EDT] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[19/07/24 08:22:10 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/07/24 08:42:28 EDT] info:account:LOGMSG_ADD_USER User '' was added.
[19/07/24 08:43:35 EDT] info:system:LOGMSG_PROTOCOL_DISABLED Service protocol readycloud is disabled.
[19/07/24 08:44:41 EDT] info:share:LOGMSG_DELETE_SHARE Share Music was deleted.
[19/07/24 08:46:10 EDT] info:share:LOGMSG_ADD_SHARE Share was added.
[19/07/24 09:02:18 EDT] info:account:LOGMSG_ADD_USER User '' was added.
[19/07/24 09:21:33 EDT] info:share:LOGMSG_DELETE_SHARE Share Pictures was deleted.
[19/07/24 09:22:29 EDT] info:share:LOGMSG_DELETE_SHARE Share Documents was deleted.
[19/07/24 09:25:03 EDT] info:share:LOGMSG_DELETE_SHARE Share was deleted.
[19/07/24 09:38:20 EDT] notice:system:LOGMSG_APPLICATION_ADD_SUCCESS_NOREBOOT Application is installed successfully.
[19/07/24 10:01:14 EDT] info:system:LOGMSG_SET_ALERTCONTACT Alert contact information was saved.
[19/07/24 10:01:14 EDT] info:system:LOGMSG_SET_ALERTCONFIG Alert settings are updated.
[19/07/24 10:01:27 EDT] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[19/08/26 12:11:58 EDT] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[19/08/26 12:12:25 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/09/01 10:46:40 EDT] notice:system:LOGMSG_SYSTEM_HALT The system is shutting down.
[19/09/01 10:46:40 EDT] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[19/09/01 15:28:15 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/09/01 15:47:41 EDT] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[19/09/01 15:48:08 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[19/11/20 17:37:17 EST] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[19/11/20 17:37:43 EST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/01/10 15:38:08 EST] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[20/01/10 15:38:33 EST] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/01 08:22:35 EDT] notice:system:LOGMSG_SYSTEM_REBOOT The system is rebooting.
[20/06/01 08:22:35 EDT] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[20/06/01 08:29:06 EDT] notice:system:LOGMSG_FIRMWARE_UPGRADED Firmware was upgraded to 6.10.3.
[20/06/01 08:29:29 EDT] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[20/06/01 08:37:15 EDT] alert:account:LOGMSG_ACCOUNT_PASSWORD_CHANGED User password has been changed.
[20/06/01 08:37:15 EDT] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[20/08/12 15:50:39 EDT] info:system:LOGMSG_PROTOCOL_ENABLED Service protocol readycloud is enabled.
[20/08/22 12:04:08 EDT] warning:volume:LOGMSG_HEALTH_VOLUME Volume data health changed from Redundant to Degraded.
[20/08/23 00:00:04 EDT] notice:system:LOGMSG_SYSTEM_HALT The system is shutting down. - StephenBAug 27, 2020Guru - Experienced User
Try looking in system.log (in your log zip), and see if there are errors around 20/08/22 12:04:08.
Also, something appears to be going wrong with your email alerts. You should fix that.
- dmachr2Sep 04, 2020Aspirant
Yeah i need to fix something in my gmail settings. I guess the main question I have now is, can these NAS drives repair themselves? I've had regular hard drives that start to show signs of failing, and then eventually fail. I know this one is redundant now, but was that a warning sign that it may fail later? And would sending the drive into WD only to get a refurbished drive be any better?
- StephenBSep 04, 2020Guru - Experienced User
No.
But we don't know what actually caused the resync - or if anything at all wrong with the disks.
It if were my own system, I'd be keeping a close eye on it, and making sure my backups are kept up to date.
