omsurf
Dec 07, 2022Follower
How do I get my Netgear router & netgear extender to use the same admin credentials w/nighthawk app?
I have a netgear router(AX2700 DOCSIS 3.1 WiFi Cable Modem Router (CAX30)) & an Extender(AC2200 WiFi Mesh Extender (EX7300v2) & each time I try to switch between products on the "network map" while ...
- Dec 07, 2022
1. I don't think you can. I think you have to log into each device separate.
2. Armor still protects all your devices, even those connected through the extender.
Dec 07, 2022Guru - Experienced User
