Danj864
Mar 10, 2020Aspirant
I need help in the Dallas/Fort Worth Texas areas
If you are trying to reach paid support, then I suggest you use my.netgear.com.
- Marc_VNETGEAR Employee Retired
Hi
It would be better if they create a SSO account first at my.netgear.com and then do the invite. This way, they will just have to login and accept the invitation.
Yes 16TB drives can be used on the RN516, Tested drives were the Seagate Ironwolf models but any NAS purposed drives that are 16TB in capacity can be used and should work with the NAS.
HTH
Regards
