DavidCX
Dec 11, 2014Aspirant
Ipad 2 streaming via readycloud or itunes
Hello - I am a novice with 4 bay readynas. I'm trying to stream music online away from my home - I have used the readycloud app but it only seems to play one song at a time - not running from one...
Dec 11, 2014Guru - Experienced User
Normal DLNA or file shares won't work without a VPN - they are not designed for over the internet usage.
You can also use plex when away from home. AVPlayerHD can be set up to access your NAS via FTP - but that is more suitable for video than music. There's always iCloud.
