AlbNet
Oct 10, 2017Apprentice
Merge my NETGEAR Accounts
I have two myNetgear accounts and I'd like to merge them (I understand that deleting one of them it's not possible). However, when I follow the merging procedure and hit the "ok" button, there is a ...
- Oct 30, 2017
Finally, got it to work after 90 minutes of chat with Netgear support
DaneA
Oct 12, 2017NETGEAR Employee Retired
Hi AlbNet,
I inquired your concern and found out that you have already opened a support ticket with NETGEAR Support. It seemed that your NETGEAR accounts are now merged into one. Were you able to verify it on your end?
DaneA
NETGEAR Community Team
- AlbNetOct 12, 2017ApprenticeHi DaneA,
Thanks for getting back to me.
I’ve just checked and they are not merged. One account has my products registered, while the other has no products. Hopefully you can help me as you are the 3rd person I wrote to and still no solution... - DaneAOct 12, 2017NETGEAR Employee Retired
Since all of your NETGEAR devices were already transferred to your one account, then, I believe this is the account you want to retain. As far as I have checked, your other account has been deactivated and you should be able to receive an e-mail notification from the NETGEAR Support regarding this. If ever you have not yet received an e-mail, you may want to follow-up on them using the support ticket you have opened.
DaneA
- AlbNetOct 12, 2017ApprenticeDaneA,
One account is not deactivated because I’ve been able to log into it few seconds ago and the products are in the other account only because I originally registered them in that account. I’m only trying to change the email of one account with the email of the other account. By doing that I get an error message that says “Email already registered with another account”. I’ve been trying to solve this issue for several days now. And no solution yet from the support team
