Mike101
Apr 24, 2017Tutor
NAS Rn104 Warning Volume media capacity 30% to 5% & System volume root's usage
Hi NAS has been offline for many weeks but I could access using local computer and IP address 192.168.... I had tried logging off, Exiting, clearing browser history and rebooting, some variants of w...
bedlam1
Apr 24, 2017Prodigy
Do you have Anti Virus enabled?
If so disable it as there are bugs with the firmware, then reboot and see what happens.
Then also consider updating your firmware
Mike101
Apr 25, 2017Tutor
Thank you. I have disabled the Anti Virus as suggested. I will see if I get any further warnings.
Am I right to presume whatever was filling up will be deleted or overwritten or was this falsely reported due to the Anti Virus software bugs?
I have not seen any media capacity indicators nor anything to identify the system volume of the roots usage. Also the log files for warnings and errors just show the messages as reported.
Will NAS users be notified when the Anti Virus can be turned back on?
(Incidentally my firmware was up to date Ver 6.6.1)
- bedlam1Apr 25, 2017Prodigy
If you are happy using Beta software this version appears to fix the Anti-Virus issue https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNASOS-6-7-1-T252-Beta-2/m-p/1266584#U1266584
- StephenBApr 26, 2017Guru - Experienced User
The fix for Anti-Virus was in 6.6.1 (which the OP is already running).
