mkarimi
Mar 12, 2020Aspirant
Netgear ReadyNas RNDP4000
Netgear ReadyNas RNDP4000 Hello, I have a ReadyNas RNDP4000 and I recently factory reset it and now I am not able to access it remotely and nor it is discoverable on the ReadyCloud. Please ad...
- Mar 12, 2020
Hi mkarimi,
You can find the instructions on this thread:
For the latest working download links, you can find it on this thread:
Please note that converting your NAS to OS6 is not supported by NETGEAR. Any support on the device will be denied by NETGEAR once you convert it to OS6.
JohnCM_S
Mar 12, 2020NETGEAR Employee Retired
Hi mkarimi,
Welcome to the Community!
May I know the current operating system of your NAS? Is it running on 4.2.x or did you convert it to OS6?
If the current operating system of your NAS is on 4.2.x, ReadyCLOUD will not detect it. Only the OS6 units have support on ReadyCLOUD.
- mkarimiMar 12, 2020Aspirant
Yes, currently it is running 4.2.31.
How I am going to convert it to OS 6?
Do you have any instructions for that?
Thanks
Manan
- JohnCM_SMar 12, 2020NETGEAR Employee Retired
Hi mkarimi,
I tried it and it is resyncing now. I tried to access it online using the IP and now the default username and password is not working. before I was using the default username name and password but now it is seem like it is not working. Is the username and password different for OS 6 version?
Thanks
Manan
