cbrinkley71
Aug 24, 2016Tutor
downloading documents from readycloud
Since the last firmware update to 6.5.1 any .pdf, .doc, or .xls file I try to download remotely (pc, or mobile) is a corrupt file with a file size of 1k. I kept thinking Netgear would figure this ou...
Aug 25, 2016Guru - Experienced User
Just want to add that some other users have also had this problem: https://community.netgear.com/t5/ReadyCLOUD/Downloading-pdf-files-from-ReadyCloud/td-p/969238
bcannon89
Aug 25, 2016Aspirant
I saw that thread eariler. The files I'm trying to download are in the root shares folder i.e. (\ReadyCLOUD\NASname\data\Documents). They file name is as generic as it can be. Specifically it's labeled "503.pdf". It's a 700kb file and it only downloads as a 1kb file that is corrupt or something. Tried opening multiple file types, naming conventions, in multiple locations and they all have this issue. So nothing in that thread is useful to our issue.
