ToddeSwe
Feb 28, 2025Guide
Ready NAS 102 app problem
Hi I've just noticed that my NAS has no app sport and after some googling and help from a facebook page of yours i got the answer to role back to 6.10.9 and i did after i'd tried 6.10.4. But i ca...
- Feb 28, 2025
ToddeSwe wrote:
Can someone please help me out here? And please i'm not an advanced user that even knows what SSL is. 🙂
See Post 37 on this thread:
That is about as simple as we can make it. But it does require use of ssh. We can give you the commands needed to copy the files from a NAS share to the correct folder.
Mar 01, 2025Guru - Experienced User
ToddeSwe wrote:
So Netgear don't have any NAS at all or have just decided to end old ones so people buy newer ones...
They are not selling any NAS.
ToddeSwe wrote:
The thing is that i'm very bad at this he writes about and i really dont know where to start.
Is it much to do? Is it to much to ask for a guide? 🙂 I feel i must at least try when i got my hand on a person like you. 🙂
A step-by-step depends on where you put the two files in his download. You want to put them in one of your NAS shares temporarily. Can you give us a share name where you can put them?
ToddeSwe
Mar 01, 2025Guide
How sad that they have ended selling NASes.
As you can see now i'm not even with you when you say this about shares, 🙂
Is it a folder or something on my NAS?
- ToddeSweMar 01, 2025Guide
Is this what you're talking about?
- StephenBMar 01, 2025Guru - Experienced User
Yes, that is the list of your shares. How does the title of that page translate into English? (I see "Shares" as the title on my page).
You need to begin by download the two files in post 37 of the discussion thread I linked to:
Then you need to copy them into one of those shares. I suggest using Backup.
You will also need to go into system->settings->services and enable ssh. Check the "enable password authentication" checkbox. There is no need to upload a key.
Do you use a Windows PC? If not, do you have a Mac? It'd be helpful to know that before giving you the other instructions.
Se a screendupm of my answer that did not wanna send:
