ToddeSwe
Feb 28, 2025Guide
Ready NAS 102 app problem
Hi I've just noticed that my NAS has no app sport and after some googling and help from a facebook page of yours i got the answer to role back to 6.10.9 and i did after i'd tried 6.10.4. But i ca...
- Feb 28, 2025
ToddeSwe wrote:
Can someone please help me out here? And please i'm not an advanced user that even knows what SSL is. 🙂
See Post 37 on this thread:
That is about as simple as we can make it. But it does require use of ssh. We can give you the commands needed to copy the files from a NAS share to the correct folder.
Mar 02, 2025Guru - Experienced User
ToddeSwe wrote:
I've downloaded the files and put them at my NAS backup/
I have allso started the putty but i get this after entering my hostname ToddeNAS
Did you remember to enable ssh as I said in post 9:
You will also need to go into system->settings->services and enable ssh. Check the "enable password authentication" checkbox. There is no need to upload a key.
ToddeSwe
Mar 02, 2025Guide
Yes i've turned on SHH in my NAS settings. Should be on somewhere else like Windows as well?
