ToddeSwe
Feb 28, 2025Guide
Ready NAS 102 app problem
Hi I've just noticed that my NAS has no app sport and after some googling and help from a facebook page of yours i got the answer to role back to 6.10.9 and i did after i'd tried 6.10.4. But i ca...
- Feb 28, 2025
ToddeSwe wrote:
Can someone please help me out here? And please i'm not an advanced user that even knows what SSL is. 🙂
See Post 37 on this thread:
That is about as simple as we can make it. But it does require use of ssh. We can give you the commands needed to copy the files from a NAS share to the correct folder.
Mar 02, 2025Guru - Experienced User
Press Accept
ToddeSwe
Mar 02, 2025Guide
I'M IN it worked but after the two black shell windows and loged in nothing more happens...
- StephenBMar 02, 2025Guru - Experienced User
Yes. I didn't give you the rest of the steps.
Now enter these commands:
cd /etc/apt cp sources.list sources.list.orig cp /data/Backup/apt.conf . cp /data/Backup/sources.list . apt-get updateNote that the bottom two cp commands end in a period - don't leave that out.
If you see any errors, stop at that point and post a screenshot.
- ToddeSweMar 02, 2025Guide
dont i have to open a window to put this lines in? What kind of window is it?
The problem is that when i write my poassword the cursor doesn't move or entering anything at all so it says the password is invalid and the window is closed. Should i use port 22 as it says?
yes.
But you are able to enter root before then?
Are you using the default admin password (which is password)? If you are, then try changing that using the NAS web ui.
No it says login: the first thing when the window is opened.
I use the same password i've set to log into my NAS webinterface as admin. I did try password now but it did not work.
Now i'm of to bed... so you have some time to think about this. So far THANKS so very much for helping me out.
- ToddeSweMar 03, 2025Guide
If i had read carefully i had noticed that you told me to put in root as a username. 🙂 I have now done all steps but there was some errors at the end, se picture. Maybe its normal?
I've just installed Transmission and when i start it in NAS settings it gives me this screen:
What to do here?
If i want to update wich one is it?
Nope
Is there a possibility that i wrote a letter or something wrong ... but don't it says so when pressing enter....
Here's the input i did
- StephenBMar 03, 2025Guru - Experienced User
ToddeSwe wrote:
Nope
The screenshots look correct, and of course transmission did install.
I don't have apps installed on my own NAS, so I can't give advice on specific apps. But none of the update packages in your earlier screenshot were appropriate for readynas.
Almost all the ReadyNAS app versions were created by third parties (not Netgear), and the folks who created them generally aren't maintaining them. One of the few exceptions is plex.
Honestly, I think you are better off installing stuff on a PC.
So sorry to hear this!
I have to buy a new one maby ... i will see if i can live with it as it is now. 🙂
HUGE thanks for the help so far.
