ToddeSwe
Feb 28, 2025Guide
Ready NAS 102 app problem
Hi I've just noticed that my NAS has no app sport and after some googling and help from a facebook page of yours i got the answer to role back to 6.10.9 and i did after i'd tried 6.10.4. But i ca...
- Feb 28, 2025
ToddeSwe wrote:
Can someone please help me out here? And please i'm not an advanced user that even knows what SSL is. 🙂
See Post 37 on this thread:
That is about as simple as we can make it. But it does require use of ssh. We can give you the commands needed to copy the files from a NAS share to the correct folder.
Mar 02, 2025Guru - Experienced User
ToddeSwe wrote:
No it says login: the first thing when the window is opened.
When you first open the window, you should be asked for the username (which is root).
Also, you should click in the window with your mouse, to make sure you have focus.
ToddeSwe
Mar 03, 2025Guide
I've just installed Transmission and when i start it in NAS settings it gives me this screen:
What to do here?
If i want to update wich one is it?
