ToddeSwe
Feb 28, 2025Guide
Ready NAS 102 app problem
Hi I've just noticed that my NAS has no app sport and after some googling and help from a facebook page of yours i got the answer to role back to 6.10.9 and i did after i'd tried 6.10.4. But i ca...
- Feb 28, 2025
ToddeSwe wrote:
Can someone please help me out here? And please i'm not an advanced user that even knows what SSL is. 🙂
See Post 37 on this thread:
That is about as simple as we can make it. But it does require use of ssh. We can give you the commands needed to copy the files from a NAS share to the correct folder.
Mar 03, 2025Guru - Experienced User
ToddeSwe wrote:
I have now done all steps but there was some errors at the end, se picture. Maybe its normal?
It looks like you forgot to copy apt.conf.
ToddeSwe
Mar 03, 2025Guide
Nope
Is there a possibility that i wrote a letter or something wrong ... but don't it says so when pressing enter....
Here's the input i did
- StephenBMar 03, 2025Guru - Experienced User
ToddeSwe wrote:
Nope
The screenshots look correct, and of course transmission did install.
I don't have apps installed on my own NAS, so I can't give advice on specific apps. But none of the update packages in your earlier screenshot were appropriate for readynas.
Almost all the ReadyNAS app versions were created by third parties (not Netgear), and the folks who created them generally aren't maintaining them. One of the few exceptions is plex.
Honestly, I think you are better off installing stuff on a PC.
- ToddeSweMar 03, 2025Guide
So sorry to hear this!
I have to buy a new one maby ... i will see if i can live with it as it is now. 🙂
HUGE thanks for the help so far.
