Cronos_IT's avatar
Cronos_IT
ReadyCloud error listing folders
Hello,
I have an issue using ReadyCloud with a RN212 (6.9.3). It's a new one.
I've created shares, users and readycloud users with all the necessary rights.
Everything works but the readycloud!
I see the shares on the network. I also see the ReadyCloud sharing with the admin readycloud account.
Services are ok.
The problem is all other readycloud users don't see any folders.
I have tried to disconnect/reconnect the NAS on the ReadyCloud, delete users and create it, using windows app, android app, web app...
I manage other NAS (RN212, 312, 402) with ReadyCloud and i have never had this problem.
Can you help me?
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi Cronos_IT
    The users needs to be invited to ReadyCloud once you have shared the folders on your ReadyNAS, they will have to create a MyNETGEAR Account to be able to login and see the shares. If a user already has an account then they will just need to login to the ReadyCloud portal to confirm the invite.
    Also, setting up share access is a bit different from local users and for ReadyCloud users. You will have to set the permissions for local users under the share settings and for ReadyCloud under the Manage tab. You can check here
    When your users login to the ReadyCloud portal or App do they see the NAS? If you can provide me a screenshot of your ReadyCloud users and also the Manage tab on ReadyCloud portal then we can check if there are any settings that needs to be changed.
    Regards
    • Cronos_IT's avatar
      Cronos_IT
      Hi,
      I've invited users, registered the accounts and allowed them to read and write the shared folders.
      The NAS is visible, but the folders aren't.
      For the test i have registered an account with the same access to different NAS i manage. The other NAS are OK (RN212 with the same rights).
ProSupport for Business
