neilvranch
Oct 18, 2016Aspirant
ReadyCLOUD off line
Hello, I have two Readynas 104 - one is working great - the other is show greyed out button on just the readycloud which will not turn off or on, also is not show ticks above showning internet or ser...
GDM52
Oct 23, 2016Aspirant
Hi "on"
Thank you for the prompt reply.
The system uses DHCP, with DNS forwarding provided by my router, sot its IP address is in the DNS swettings.
The system has not been factory reset for at least 2 years. ReadyCloud appears to be functioninig in some way (I can see files in PC client) but slider button to start / stop in ReadyNAS admin page always reverts to off when I try to switch it to "on"
Will send logs in 2 mins
Hope you can help.
Thanks again
mdgm-ntgr
Oct 24, 2016NETGEAR Employee Retired
It seems your ReadyNAS is still registered to the old ReadyCLOUD account.
