shaunleblanc
Oct 22, 2017Aspirant
ReadyNas 102 w/ Firmware 6.8.1 + ReadyCloud V2.0.0 on iOS 11 - Media Backup Not Working
ReadyNas 102 w/ Firmware 6.8.1 + ReadyCloud V2.0.0 on iOS 11 - Media Backup Not Working Since updating to the above details the media backup won't work. It will sit in a state of uploading and never...
Anonymous
Oct 28, 2017Hi shaunleblanc,
Have you tried uninstalling and re-installing the iOS app and check if you will still have the same issue?
Welcome to the community!
JohnM_S
NETGEAR Community Team
shaunleblanc
Oct 29, 2017Aspirant
Hi John,
I did delete and re-install twice and still no luck. I'm seeing others who are on iOS 11 are posting similar issues so I'm wondering if the ReadyCloud app doesn't play well with iOS 11.
- Shaun
- dhamsherOct 29, 2017Tutor
I am having the same trouble. Netgear, when will this be fixed? I think that it may relate to the new HEIC file format.
- BaldmanOct 29, 2017Aspirant
Same issue here. Reainstalled the app twice now and there are zero uploads going on.
NETGEAR...pls give us all a response.....
Tks
