miket82
May 14, 2016Follower
ReadyNAS 102
Received an email from netgear informing me I should change my readycloud account to a mynetgear account and then upgrade my readynas 102 to version 6.5. Have created and can open mynetgear account...
- May 14, 2016
The email is confusing, but if you read it carefully, you'll see the phrase "After the transition..." That transition hasn't happened yet.
6.5 is in beta (release candidate RC3) and I expect it will be released shortly (likely a few days). Then the ReadyCloud SSO transition will start. 6.5 will be the next firmware release for your RN102.
May 14, 2016Guru - Experienced User
JennC
May 14, 2016NETGEAR Employee Retired
Hello miket82,
Hopefully next week is the release if 6.5.0.
ReadyCloud will be available to 6.5.0 only, meaning, older firmware will no longer have access to ReadyCloud. Make sure to upgrade your ReadyCloud account as well as those accounts that are invited to access your NAS once you update to 6.5.0.
Welcome to the community!
