Kenflynn81
Mar 01, 2022Aspirant
ReadyNAS 422 Missing copied folders from Share
I'm a little new-ish at the NAS system but had my old hard drive degrade out on me and had to replace it. I took the long route by copying everything over to a backup drive, then installed the new WD...
- Mar 01, 2022
Kenflynn81 wrote:
When I went to transfer to the new HD I did not recreate new share fodlers on the system. I used Windows Map Network Drive to show it was a Z Drive to access the HD from windows and copied/pasted that way.
That is the problem. A share is different from a windows folder you create directly in /data in a number of ways.
Unfortunately the only way to fix it is to delete all the data, create shares, and then copy the data into the shares.
Kenflynn81
It shows the data on the HD however it shows on the cloud as Snapshot instead of data for some reason.
I'll attach a photo of what I'm meaning
one is showing the Coud data
2nd is windows dat screen showing the data is there.Windows dataCloud photo
Mar 01, 2022Guru - Experienced User
- Kenflynn81Mar 01, 2022Aspirant
I will start doing that now. Thank you for the help. I wished I'd thought of doing that before transfering all the data on the hard drive, took nearly a day to get everything moved over. BUT at least I'll be able to get it working again.
thank you again StephenB
Kenneth Flynn
- StephenBMar 01, 2022Guru - Experienced User
One thing you could try:
- rename one of the root folders in data from windows
- create the share using the original root folder name
- copy the files into the share from windows (using your mapped drive).
- delete the renamed folder.
That should work, and would probably be faster than copying everything again.
