Toronto_User
Nov 27, 2022Aspirant
ReadyNAS Ultra 4 - TLS outdated - how to upgrade TLS to 1.2?
Sorry if this is old ground, but I don't want to screw up my ReadyNAS by making an error. I have a ReadyNAS Ultra 4 Plus running firmware 4.2.31. I cannot access the admin control panel from Mac ...
Nov 28, 2022Guru - Experienced User
Toronto_User wrote:
If there's an upgrade .bin package that can do the job, that would be ideal. Can anyone help? Many thanks.
There is an extensive thread on this topic here:
The short answer is that you can still gain access using internet explorer (or Edge in IE mode). If you can't do that, then you can still download an old version of firefox (94.0.2 works).
Once in, you can install this add-on:
Note, you can also convert your Ultra to run OS-6 firmware, which would add some more features (including SMB 3 support).
Anton_
Dec 04, 2022Tutor
Yeah, im running the 4 Ultra as well. I recommend running OS 6.
If you dont strongly require to use old OS.
