andyhogg19
Feb 13, 2019Aspirant
RN21200-100NES offline alert once per day
Bought a new RN21200-1-- NES 2 weeks ago. I notice every day i get an offline alert generated and then an online alert one or two minutes later. Seems to happen evry day at different times. Would I ...
Marc_V
Feb 13, 2019NETGEAR Employee Retired
Hi andyhogg19
Can you send me your full logs thru PM? you can give me a link using google drive?
Many thanks!
Marc_V
Feb 14, 2019NETGEAR Employee Retired
Hi andyhogg19
Is the NAS directly connected on the router? or connecting to a switch or wall mount?
Tehre are Eth link changes that might be the cause of the alert and this might be because of the physical connection from the NAS.
Have you tried changing cable or changing the port where it is connected?
Regards
- schumakuFeb 14, 2019Guru - Experienced User
We see random, almost daily Insight Offline alerts for our ReadyNAS systems (Inhell 6.10 Beta 1 as of writing), too. Rock solid networks (XS724EM, XS728T, XS748T, ...) - no indications of Ethernet issues, neither on the ReadyNAS nor on the switch and router infrastructure - which is serving as a backbone for some Insight switches and Insight WAC, too. Reporting almost once a week to the Insight team since day one of Beta 8-/
- StephenBFeb 14, 2019Guru - Experienced User
Yes. I think this is most likely an issue with the Insight cloud itself.
- schumakuFeb 17, 2019Guru - Experienced User
However, the issue exists with ReadyNAS only, not with any other Insight managed device. Can't be this does take years to be addressed Marc_V - we shared the information requested here again many times with Netgear before.
