ericatk
Jan 01, 2015Aspirant
Very frustrated setting this up
Seems there are a lot of out dated instructions. Spent a lot of time reading and re-reading.
Mac OSX Yosemite 10.10.1 Nas 10400 2 - 3 tb wd red drives
OK here are the issues:
Created account found NAS on network. Had a fun time trying to find invite user button !$^%#$@ does not exist anymore
1) Downloaded ReadyCloud app cannot for the life of me log in to this
2) I have been able to drag and drop items into the folders but can't import because I can't go in through Readycloud app
3) iTunes enabled and I can find the ReadyNas in iTunes but none of the music??? (I dragged and dropped from Chrome into the folders on ReadyNAS)
Services enabled: SMB,AFP,iTunes, ReadyDLNA,Rsync,UPnP,HTTP,HTTPS,ANTIVirus
Frustrated and may have to have a couple of drinks to conquer... :slap:
- NhellieVirtuosoReadyCloud App on MAC is still on beta. Try downloading this one:
https://readycloud.netgear.com/client/i ... yCLOUD.pkg
or
http://www.readynas.com/contributed/mdg ... 1.2.15.pkg
What FW are you using btw? - ericatkAspirantThanks both of those downloads worked..
FW?
Firewall? - beustaceAspirantHi ericatk and other fellow Mac 10.10 users..., Just wondering if you have managed to get the Mac 10.10 to work with ReadyNas Remote or ReadyNas Cloud. I don't seem to be able to get it to work here either. ReadyCloud comes up with Online (VPN disconnected). Am trying to get the ReadyDrop to work.
Cheers - Brad. - ericatkAspirant
beustace wrote: Hi ericatk and other fellow Mac 10.10 users..., Just wondering if you have managed to get the Mac 10.10 to work with ReadyNas Remote or ReadyNas Cloud. I don't seem to be able to get it to work here either. ReadyCloud comes up with Online (VPN disconnected). Am trying to get the ReadyDrop to work.
Cheers - Brad.
I was able to get them working after downloading the links from above. I still have not got the iTunes server to work yet - NhellieVirtuoso
ericatk wrote: Thanks both of those downloads worked..
FW?
Firewall?
Firmware version :) - NhellieVirtuoso
Cheers - Brad.
Try opening port 6300 if you are still getting the VPN Disconnected error
