Alex_CCIM
Feb 23, 2017Apprentice
8th Channel not able to be viewed on PC desktop program
Hello All, I just purchased the 8th channel (camera) for ReadyNAS Surveillance on my RN214. The Surveillance Configuration sees the 8th camera. I have fully set it up. It shows that it is live an...
- Feb 27, 2017
Hello Alex_CCIM,
Have you tried reinstalling the desktop app? Or, maybe turn off one of the 7 already existing cameras then see if this last one you joined in gets the same results.
JennC
Feb 27, 2017NETGEAR Employee Retired
Hello Alex_CCIM,
Alex_CCIM
Feb 27, 2017Apprentice
JennC,
I have changed the cameras around and it is always channel 8. I can't find the install software to re-install. Can you provide a link?
Thank you,
-Alex
