ygator
Feb 10, 2013Aspirant
AddOn not working and cannot be removed
ReadyNAS Duo V2 I followed the instructions for creating an addon from http://www.readynas.com/?p=346. I was able to install the addon. However, when trying to run it by clicking on save a spin...
ygator
Feb 14, 2013Aspirant
The errors I posted above are bugs in the following files:
For the image errors
/frontview/dashboard/index.html
/frontview/dashboard/dashboard.html
/frontview/dashboard/wizard.html
For the install errors
/frontview/dashboard/legacy/addons/installed/installed.html
/opt/installed/installed.html
Okay I have found some problems in the SDK located http://www.readynas.com/download/addons/addons_sdk.tgz that was causing it not to work.
addons_sdk\template\ADDON.xml
<get_url>/addons/%ADDON%_HANDLER.pl</get_url>
<set_url>/addons/%ADDON%_HANDLER.pl</set_url>
should be changed to
<get_url>%ADDON%_HANDLER.pl</get_url>
<set_url>%ADDON%_HANDLER.pl</set_url>
addons_sdk\addon.config
RESTART_APACHE="n"
RESTART_APACHE="y"
There is one more issue where it does not save the runtime seconds into /etc/default/services file.
I will look into that tomorrow.
RESTART_APACHE="n"
RESTART_APACHE="y"
