super_poussin
May 09, 2013Virtuoso
Addons available For R6
Hello Guys,
A quick list with port used by application
Application Port 1 Port 2 Port 3
mysql 3306
subsonic 4040 4041
shellinabox 4200
istat 5109
phpmywadmin 7082
ajaxplorer 7084
piwigo 7091
glpi 7092
magento 7093
drupal 7094
wordpress 7095
joomla 7096
Qbittorrent 7097
Tinyrss 7098
btsync 7099
koken 7100
gateone 7101
barracuda 7103 7443
novius 7104
transmission 8181
lms 9000
twonky 9050
vpnserver 14443 1194 5555
vpnclient 14443 1194 5555
python
automatic
selfoss 7106
DDClient
New : Monsta FTP Client and PHPSysInfo and also amule and cacti and owncloud
New (11/22/2013) Aria2 with web interface a powerful download manager :)
New (11/27/2013) Cups Print Server :)
New (12/12/2013) Owncloud 6.0.0 :)
New recoll version 2015 :)
New utorrent for x86 2015 :)
You can find all my addons in a drop box : https://www.dropbox.com/sh/ie9pwk1wut72ias/p6_X2QeOIC
If you don not have dropbox installed use this link to install it, so I will have more space to share addons : http://db.tt/v4mPZg7l
mysql 3306
subsonic 4040 4041
shellinabox 4200
istat 5109
phpmywadmin 7082
ajaxplorer 7084
piwigo 7091
glpi 7092
magento 7093
drupal 7094
wordpress 7095
joomla 7096
Qbittorrent 7097
Tinyrss 7098
btsync 7099
koken 7100
gateone 7101
barracuda 7103 7443
novius 7104
transmission 8181
lms 9000
twonky 9050
python
automatic
selfoss 7106
DDClient
- mdgm-ntgrNETGEAR Employee RetiredI assume the new version of the add-on should be safe (though it would be a good idea to ensure your backup is up to date before you install it, just in case). I think super-poussin wouldn't have made a new version available if it wasn't safe.
- beniroquaiAspirantHey. Great work! Thank you very much! :) Is there any chance of getting the owncloud add-on to work on OS6? Its availible in the genie-appstore, but this is not working with the selfinstalled OS6 version on older readynasses?
- super_poussinVirtuoso
beniroquai wrote: Hey. Great work! Thank you very much! :) Is there any chance of getting the owncloud add-on to work on OS6? Its availible in the genie-appstore, but this is not working with the selfinstalled OS6 version on older readynasses?
I heard Netgear could provide an owncloud version for R6 - beniroquaiAspirantWhat do you mean by "netgear could provide a owncloud installation"?
That they could provide their own add-on.beniroquai wrote: What do you mean by "netgear could provide a owncloud installation"? - olestGuideTried vpnserver with 6.1.1 beta and uninstalled it again even though it worked fine.
When I try to install vpnserver after updating to 6.1.1 final it say it is installed successfully but I cannot see it under installed apps and it is not working. - olestGuideI just saw that VPN server (version 1.1.9) is in "Available Apps" and that one installs fine.
- olestGuideWhen I establish a L2TP connection to vpn server from outside I can see every other server in the same network as the NAS but not the NAS it self.
Does anyone know hos to fix this? olest wrote: When I establish a L2TP connection to vpn server from outside I can see every other server in the same network as the NAS but not the NAS it self.
+1
Also, I need to set the Readynas IP to the DMZ on my router for me to be able to connect to my network from outside. Can anyone explain why this is, what risk there is and whether it can be avoided through eg port forwarding?- olestGuideIf you use L2TP you have to forward port 500 UDP and 4500 UDP to the NAS.
Access to the NAS it self is a limitation in the VPN server software I found but you can get it working anyway if you in the Local bridge setup add a TAP interface and in the Virtual hub enable secure NAT. You then have to access the NAS at the TAP interface.
