pic1234
Feb 17, 2017Aspirant
allow permission readynas folder torrent
Installed Transmission torrent dowloader on Readynas 102 Firmw 6.6.1 I set the download folder outside the apps folder as /Video/_QDownloads permission to write in this folder is denied How can I...
- Feb 28, 2017
pic1234 wrote:
Well on the folder where I wanted to record downloaded files from Transmission torrent client, rights are set to read/write for everyone
However if I create a new folder from scratch and I set it for downloading files then they are written correctly
The difference between the two folders is that in the new folder the DLNA service is not active
Are the torrents directly stored in the download folder, or are they copied there after the torrent completes?
If the DLNA scanner tries to scan the a media file that isn't fully downloaded, it will of course run into corruption in the file. That could easily create problems with the scanning.
FramerV
Feb 24, 2017NETGEAR Employee Retired
Hi pic1234,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
pic1234
Feb 27, 2017Aspirant
Sorry it took a while to check response:
thanks
- FramerVFeb 27, 2017NETGEAR Employee Retired
Hi pic1234,
Can you try to disable the DLNA, reboot the NAS then enable the DLNA on the folder that you wish to use?
- StephenBFeb 28, 2017Guru - Experienced User
