Sylphide
Aug 11, 2014Tutor
Android playback when record on motion detection
Is it possible to have playback function in Android app if I record only on motion detection?
Currently I can only set the date/time/duration, which I obviously ignore if it is triggered on motion detection.
- SylphideTutoris this Add-On still supported?
I see last version updated is 2012... - mdgm-ntgrNETGEAR Employee RetiredThere is an add-on from mid-2013: http://support.netgear.com/product/RNNVR01L-1000S
- SylphideTutorOK thanks. I suppose this update is already in my Nas app store.
Do you have an idea about my initial question? - mdgm-ntgrNETGEAR Employee RetiredI asked the ReadyNAS PLM and it's not currently possible.
- SylphideTutorI hope it is planned for a future release. I cannot buy cameras licenses if the playback/sound does not work (DCS 942L) on mobile...
- mdgm-ntgrNETGEAR Employee RetiredYou can setup an email or push notification to the mobile app when motion is detected. Then you know when to look for video on your PC.
- SylphideTutorWell...
- email notifications were not working for me (my smtp server is ok, working fine with other apps)
- I always get "No data" in playback, even if the time is correct
I will wait for the next major update.
