gbeddow
Sep 23, 2016Luminary
Antivirus false positives
Hi, ReadyNAS Antivirus is flagging a couple of files in the current version of WordPress, zxcvbn-async.min.js and wp-fullscreen-stub.min.js, but there doesn't appear to be anything wrong with the...
gbeddow
Sep 27, 2016Luminary
You can find these 2 files here:
JennC
Sep 27, 2016NETGEAR Employee Retired
Hello gbeddow,
Thanks but how do I download this? I'm just trying to copy it and test on our own NAS.
- gbeddowSep 27, 2016Luminary
As usual there are lots of ways. You could copy the contents of each file from the links above, then save locally. Another way is to back up one level in github and click the download button
https://github.com/WordPress/WordPress
then unzip the file and locate the 2 files in the resulting directory hierarchy here:
WordPress/wp-admin/js/wp-fullscreen-stub.min.js
WordPress/wp-includes/js/zxcvbn-async.min.js - JennCSep 27, 2016NETGEAR Employee Retired
Hello gbeddow,
How do you copy them over? I used the web browser and files but did not get the same problem. By the way, I copied to notepad and saved as .js file.
Hi JennC,
It's not clear to me what's happening for you. Can you describe the steps you're taking in more detail?
Thanks,
Greg
- OOM-9Sep 27, 2016NETGEAR Expert
I am seeing the issue with the following file:
I will forward this file information through our channels.
I am not seeing the issue with this file:
WordPress/wp-includes/js/zxcvbn-async.min.js - B_LSep 28, 2016NETGEAR Expert
Thank you for reporting this issue. It was fixed in the AV definiation update. Please make sure your AV definition file is up-to-date. The version should be 201609281626 or late.
You can install Anti-Vius Plus app, click the "Cehck Update" button to update the definition file.
There is a known bug that the "Definition File" is empty in Anti-Virus Plus app 2.0.4. It will be fixed in the next release 2.0.5.
- gbeddowSep 28, 2016Luminary
B_L,
Thanks. I turned Antivirus back on a few hours ago and, so far, it hasn't flagged these 2 files - or any other files. Keeping my fingers crossed...
