sunsina
Aug 12, 2015Guide
Any plan for officially upgrading pydio and php?
I am wondering why the appications on the application market OS 6.3.5 are so outdated. As an example Pydio is very outdated (v5.2.3) and the latest version is 6.0.8 (which recommends php >5.6.x) Ne...
super_poussin
Aug 24, 2015Virtuoso
can you try
apt-get install php5
to force upgrade ?
sunsina
Aug 24, 2015Guide
Ok,
I tried following commands with following results.
Meanwhile(after execution of commands) I tried to install pydio via GUI and terminal
I executed following commands (in sequence)
root@RDNASOS6-X:~# apt-get install php5 Reading package lists... Done Building dependency tree Reading state information... Done php5 is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 54 not upgraded. root@RDNASOS6-X:~# apt-get update Hit http://security.debian.org wheezy/updates InRelease Ign http://mirrors.kernel.org wheezy InRelease Hit http://security.debian.org wheezy/updates/main amd64 Packages Hit http://mirrors.kernel.org wheezy Release.gpg Hit http://mirrors.kernel.org wheezy Release Hit http://mirrors.kernel.org wheezy/main amd64 Packages Ign http://apt.readynas.com 6.4.0 InRelease Get:1 http://apt.readynas.com 6.4.0 Release.gpg [490 B] Get:2 http://apt.readynas.com 6.4.0 Release [22.2 kB] Hit http://apt.readynas.com 6.4.0/updates amd64 Packages Hit http://apt.readynas.com 6.4.0/apps amd64 Packages Hit http://apt.readynas.com 6.4.0/main amd64 Packages Fetched 22.7 kB in 7s (2,869 B/s) Reading package lists... Done root@RDNASOS6-X:~# apt-get install php5 Reading package lists... Done Building dependency tree Reading state information... Done php5 is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 54 not upgraded.
apt-get upgrade .....
root@RDNASOS6-X:~# apt-get install php5 Reading package lists... Done Building dependency tree Reading state information... Done php5 is already the newest version. 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. 4 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] Setting up nut-client (2.7.3-0.netgear2) ... insserv: warning: script 'leafp2p' missing LSB tags and overrides [....] Restarting nut-client (via systemctl): nut-client.serviceJob failed. See system journal and ' failed! invoke-rc.d: initscript nut-client, action "restart" failed. dpkg: error processing nut-client (--configure): subprocess installed post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of nut-server: nut-server depends on nut-client (= 2.7.3-0.netgear2); however: Package nut-client is not configured yet. dpkg: error processing nut-server (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nut: nut depends on nut-server; however: Package nut-server is not configured yet. nut depends on nut-client; however: Package nut-client is not configured yet. dpkg: error processing nut (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nut-snmp: nut-snmp depends on nut (>= 1.4.1-pre1); however: Package nut is not configured yet. dpkg: error processing nut-snmp (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: nut-client nut-server nut nut-snmp E: Sub-process /usr/bin/dpkg returned an error code (1)
root@RDNASOS6-X:/tmp# dpkg -i pydio_6.0.8_all.deb Selecting previously unselected package pydio. (Reading database ... 16200 files and directories currently installed.) Unpacking pydio (from pydio_6.0.8_all.deb) ... --2015-08-24 20:51:35-- http://www.dotdeb.org/dotdeb.gpg Resolving www.dotdeb.org (www.dotdeb.org)... 195.154.242.153 Connecting to www.dotdeb.org (www.dotdeb.org)|195.154.242.153|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 5299 (5.2K) [application/octet-stream] Saving to: ‘dotdeb.gpg’ dotdeb.gpg 100%[====================================>] 5.17K --.-KB/s in 0s 2015-08-24 20:51:35 (114 MB/s) - ‘dotdeb.gpg’ saved [5299/5299] OK dpkg: dependency problems prevent configuration of pydio: pydio depends on php5-gd (>= 5.6.4~); however: Version of php5-gd on system is 5.4.41-0+deb7u1. pydio depends on php5-pthreads; however: Package php5-pthreads is not installed. dpkg: error processing pydio (--install): dependency problems - leaving unconfigured Errors were encountered while processing: pydio
root@RDNASOS6-X:/tmp# apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded. 4 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up nut-client (2.7.3-0.netgear2) ... insserv: warning: script 'leafp2p' missing LSB tags and overrides [....] Restarting nut-client (via systemctl): nut-client.serviceJob failed. See system journal and 'systemctl status' for details. failed! invoke-rc.d: initscript nut-client, action "restart" failed. dpkg: error processing nut-client (--configure): subprocess installed post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of nut-server: nut-server depends on nut-client (= 2.7.3-0.netgear2); however: Package nut-client is not configured yet. dpkg: error processing nut-server (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nut: nut depends on nut-server; however: Package nut-server is not configured yet. nut depends on nut-client; however: Package nut-client is not configured yet. dpkg: error processing nut (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nut-snmp: nut-snmp depends on nut (>= 1.4.1-pre1); however: Package nut is not configured yet. dpkg: error processing nut-snmp (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: nut-client nut-server nut nut-snmp E: Sub-process /usr/bin/dpkg returned an error code (1)
NOTHING WORKED
I am wondering why there is no plan to bring this app PHP >5.6/Pydio 6.0.8 into the ReadyNAS OS AppMarket !??
- super_poussinAug 24, 2015Virtuoso
sounds like something is missin on your nas , very strange
can you do this :
cd /etc/apt/sources.list.d/
then creat a file called dotdeb.list
and put in it :
deb http://packages.dotdeb.org wheezy-php56 all deb-src http://packages.dotdeb.org wheezy-php56 all
save the file and do
apt-get update
then install pydio
- sunsinaAug 26, 2015Guide
Ok, I tried your solution.
It installed PHP5.6 with couple of errors (but php5-threads does not install)The following extra packages will be installed: libapache2-mod-php5 libphp5-embed libt1-5 libvpx1 php5-cli php5-common php5-curl php5-gd php5-imap php5-mcrypt php5-mysql Suggested packages: php5-user-cache Recommended packages: php5-readline The following NEW packages will be installed: libt1-5 libvpx1 The following packages will be upgraded: libapache2-mod-php5 libphp5-embed php5 php5-cli php5-common php5-curl php5-gd php5-imap php5-mcrypt php5-mysql 10 upgraded, 2 newly installed, 0 to remove and 4 not upgraded. 4 not fully installed or removed. Need to get 10.6 MB of archives. After this operation, 5,826 kB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://packages.dotdeb.org/ wheezy-php56/all php5-mysql amd64 5.6.12-1~dotdeb+7.1 [86.1 kB] Get:2 http://packages.dotdeb.org/ wheezy-php56/all php5-mcrypt amd64 5.6.12-1~dotdeb+7.1 [18.0 kB] Get:3 http://mirrors.kernel.org/debian/ wheezy/main libvpx1 amd64 1.1.0-1 [290 kB] Get:4 http://packages.dotdeb.org/ wheezy-php56/all php5-imap amd64 5.6.12-1~dotdeb+7.1 [38.0 kB] Get:5 http://packages.dotdeb.org/ wheezy-php56/all php5-gd amd64 5.6.12-1~dotdeb+7.1 [142 kB] Get:6 http://packages.dotdeb.org/ wheezy-php56/all php5-cli amd64 5.6.12-1~dotdeb+7.1 [2,960 kB] Get:7 http://mirrors.kernel.org/debian/ wheezy/main libt1-5 amd64 5.1.2-3.6 [174 kB] Get:8 http://packages.dotdeb.org/ wheezy-php56/all libphp5-embed amd64 5.6.12-1~dotdeb+7.1 [3,044 kB] Get:9 http://packages.dotdeb.org/ wheezy-php56/all php5-curl amd64 5.6.12-1~dotdeb+7.1 [34.1 kB] Get:10 http://packages.dotdeb.org/ wheezy-php56/all libapache2-mod-php5 amd64 5.6.12-1~dotdeb+7.1 [3,045 kB] Get:11 http://packages.dotdeb.org/ wheezy-php56/all php5-common amd64 5.6.12-1~dotdeb+7.1 [763 kB] Get:12 http://packages.dotdeb.org/ wheezy-php56/all php5 all 5.6.12-1~dotdeb+7.1 [1,192 B] Fetched 10.6 MB in 7s (1,338 kB/s) debconf: delaying package configuration, since apt-utils is not installed Selecting previously unselected package libvpx1:amd64. (Reading database ... 16201 files and directories currently installed.) Unpacking libvpx1:amd64 (from .../libvpx1_1.1.0-1_amd64.deb) ... Preparing to replace php5-mysql 5.4.41-0+deb7u1 (using .../php5-mysql_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-mysql ... Preparing to replace php5-mcrypt 5.4.41-0+deb7u1 (using .../php5-mcrypt_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-mcrypt ... Preparing to replace php5-imap 5.4.41-0+deb7u1 (using .../php5-imap_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-imap ... Selecting previously unselected package libt1-5. Unpacking libt1-5 (from .../libt1-5_5.1.2-3.6_amd64.deb) ... Preparing to replace php5-gd 5.4.41-0+deb7u1 (using .../php5-gd_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-gd ... Preparing to replace php5-cli 5.4.41-0+deb7u1 (using .../php5-cli_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-cli ... Preparing to replace libphp5-embed 5.4.41-0+deb7u1 (using .../libphp5-embed_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement libphp5-embed ... Preparing to replace php5-curl 5.4.41-0+deb7u1 (using .../php5-curl_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-curl ... Preparing to replace libapache2-mod-php5 5.4.41-0+deb7u1 (using .../libapache2-mod-php5_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement libapache2-mod-php5 ... Preparing to replace php5-common 5.4.41-0+deb7u1 (using .../php5-common_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-common ... dpkg: warning: unable to delete old directory '/etc/php5/conf.d': Directory not empty Preparing to replace php5 5.4.41-0+deb7u1 (using .../php5_5.6.12-1~dotdeb+7.1_all.deb) ... Unpacking replacement php5 ... Setting up nut-client (2.7.3-0.netgear2) ... insserv: warning: script 'leafp2p' missing LSB tags and overrides [....] Restarting nut-client (via systemctl): nut-client.serviceJob failed. See system journal and 'systemctl status' for details. failed! invoke-rc.d: initscript nut-client, action "restart" failed. dpkg: error processing nut-client (--configure): subprocess installed post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of nut-server: nut-server depends on nut-client (= 2.7.3-0.netgear2); however: Package nut-client is not configured yet. dpkg: error processing nut-server (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nut: nut depends on nut-server; however: Package nut-server is not configured yet. nut depends on nut-client; however: Package nut-client is not configured yet. dpkg: error processing nut (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of nut-snmp: nut-snmp depends on nut (>= 1.4.1-pre1); however: Package nut is not configured yet. dpkg: error processing nut-snmp (--configure): dependency problems - leaving unconfigured Setting up libvpx1:amd64 (1.1.0-1) ... Setting up php5-common (5.6.12-1~dotdeb+7.1) ... Installing new version of config file /etc/cron.d/php5 ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline php5_invoke: Enable module pdo for cli SAPI php5_invoke: Enable module pdo for embed SAPI php5_invoke: Enable module pdo for apache2 SAPI debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline Creating config file /etc/php5/mods-available/opcache.ini with new version php5_invoke: Enable module opcache for cli SAPI php5_invoke: Enable module opcache for embed SAPI php5_invoke: Enable module opcache for apache2 SAPI Setting up php5-mysql (5.6.12-1~dotdeb+7.1) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline php5_invoke: Enable module mysql for cli SAPI php5_invoke: Enable module mysql for embed SAPI php5_invoke: Enable module mysql for apache2 SAPI debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline php5_invoke: Enable module mysqli for cli SAPI php5_invoke: Enable module mysqli for embed SAPI php5_invoke: Enable module mysqli for apache2 SAPI debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline php5_invoke: Enable module pdo_mysql for cli SAPI php5_invoke: Enable module pdo_mysql for embed SAPI php5_invoke: Enable module pdo_mysql for apache2 SAPI Setting up php5-mcrypt (5.6.12-1~dotdeb+7.1) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline php5_invoke: Enable module mcrypt for cli SAPI php5_invoke: Enable module mcrypt for embed SAPI php5_invoke: Enable module mcrypt for apache2 SAPI Setting up php5-imap (5.6.12-1~dotdeb+7.1) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline php5_invoke: Enable module imap for cli SAPI php5_invoke: Enable module imap for embed SAPI php5_invoke: Enable module imap for apache2 SAPI Setting up libt1-5 (5.1.2-3.6) ... Setting up php5-gd (5.6.12-1~dotdeb+7.1) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline php5_invoke: Enable module gd for cli SAPI php5_invoke: Enable module gd for embed SAPI php5_invoke: Enable module gd for apache2 SAPI Setting up php5-cli (5.6.12-1~dotdeb+7.1) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline Replacing config file /etc/php5/cli/php.ini with new version Setting up libphp5-embed (5.6.12-1~dotdeb+7.1) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline Replacing config file /etc/php5/embed/php.ini with new version Setting up php5-curl (5.6.12-1~dotdeb+7.1) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline php5_invoke: Enable module curl for cli SAPI php5_invoke: Enable module curl for embed SAPI php5_invoke: Enable module curl for apache2 SAPI Setting up libapache2-mod-php5 (5.6.12-1~dotdeb+7.1) ... Installing new version of config file /etc/apache2/mods-available/php5.conf ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline Replacing config file /etc/php5/apache2/php.ini with new version Setting up php5 (5.6.12-1~dotdeb+7.1) ... Processing triggers for libc-bin ... Errors were encountered while processing: nut-client nut-server nut nut-snmp E: Sub-process /usr/bin/dpkg returned an error code (1) root@RDNASOS6-X:/etc/apt/sources.list.d# apt-get update Hit http://security.debian.org wheezy/updates/main amd64 Packages Get:2 http://packages.dotdeb.org wheezy-php56/all Sources [8,273 B] Get:3 http://packages.dotdeb.org wheezy-php56/all amd64 Packages [16.5 kB] Ign http://apt.readynas.com 6.4.0 InRelease Get:4 http://apt.readynas.com 6.4.0 Release.gpg [490 B] Ign http://mirrors.kernel.org wheezy InRelease Hit http://mirrors.kernel.org wheezy Release.gpg Hit http://mirrors.kernel.org wheezy Release Get:5 http://apt.readynas.com 6.4.0 Release [22.2 kB] Hit http://mirrors.kernel.org wheezy/main amd64 Packages Hit http://apt.readynas.com 6.4.0/updates amd64 Packages Hit http://apt.readynas.com 6.4.0/apps amd64 Packages Hit http://apt.readynas.com 6.4.0/main amd64 Packages Fetched 51.4 kB in 4s (11.7 kB/s) Reading package lists... Done root@RDNASOS6-X:/etc/apt/sources.list.d# apt-get install php5 Reading package lists... Done Building dependency tree Reading state information... Done The following extra packages will be installed: libapache2-mod-php5 libphp5-embed libt1-5 libvpx1 php5-cli php5-common php5-curl php5-gd php5-imap php5-mcrypt php5-mysql Suggested packages: php5-user-cache Recommended packages: php5-readline The following NEW packages will be installed: libt1-5 libvpx1 The following packages will be upgraded: libapache2-mod-php5 libphp5-embed php5 php5-cli php5-common php5-curl php5-gd php5-imap php5-mcrypt php5-mysql 10 upgraded, 2 newly installed, 0 to remove and 4 not upgraded. 4 not fully installed or removed. Need to get 10.6 MB of archives. After this operation, 5,826 kB of additional disk space will be used. Do you want to continue? [Y/n] Get:1 http://packages.dotdeb.org/ wheezy-php56/all php5-mysql amd64 5.6.12-1~dotdeb+7.1 [86.1 kB] Get:2 http://packages.dotdeb.org/ wheezy-php56/all php5-mcrypt amd64 5.6.12-1~dotdeb+7.1 [18.0 kB] Get:3 http://mirrors.kernel.org/debian/ wheezy/main libvpx1 amd64 1.1.0-1 [290 kB] Get:4 http://packages.dotdeb.org/ wheezy-php56/all php5-imap amd64 5.6.12-1~dotdeb+7.1 [38.0 kB] Get:5 http://packages.dotdeb.org/ wheezy-php56/all php5-gd amd64 5.6.12-1~dotdeb+7.1 [142 kB] Get:6 http://packages.dotdeb.org/ wheezy-php56/all php5-cli amd64 5.6.12-1~dotdeb+7.1 [2,960 kB] Get:7 http://mirrors.kernel.org/debian/ wheezy/main libt1-5 amd64 5.1.2-3.6 [174 kB] Get:8 http://packages.dotdeb.org/ wheezy-php56/all libphp5-embed amd64 5.6.12-1~dotdeb+7.1 [3,044 kB] Get:9 http://packages.dotdeb.org/ wheezy-php56/all php5-curl amd64 5.6.12-1~dotdeb+7.1 [34.1 kB] Get:10 http://packages.dotdeb.org/ wheezy-php56/all libapache2-mod-php5 amd64 5.6.12-1~dotdeb+7.1 [3,045 kB] Get:11 http://packages.dotdeb.org/ wheezy-php56/all php5-common amd64 5.6.12-1~dotdeb+7.1 [763 kB] Get:12 http://packages.dotdeb.org/ wheezy-php56/all php5 all 5.6.12-1~dotdeb+7.1 [1,192 B] Fetched 10.6 MB in 7s (1,338 kB/s) debconf: delaying package configuration, since apt-utils is not installed Selecting previously unselected package libvpx1:amd64. (Reading database ... 16201 files and directories currently installed.) Unpacking libvpx1:amd64 (from .../libvpx1_1.1.0-1_amd64.deb) ... Preparing to replace php5-mysql 5.4.41-0+deb7u1 (using .../php5-mysql_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-mysql ... Preparing to replace php5-mcrypt 5.4.41-0+deb7u1 (using .../php5-mcrypt_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-mcrypt ... Preparing to replace php5-imap 5.4.41-0+deb7u1 (using .../php5-imap_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-imap ... Selecting previously unselected package libt1-5. Unpacking libt1-5 (from .../libt1-5_5.1.2-3.6_amd64.deb) ... Preparing to replace php5-gd 5.4.41-0+deb7u1 (using .../php5-gd_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-gd ... Preparing to replace php5-cli 5.4.41-0+deb7u1 (using .../php5-cli_5.6.12-1~dotdeb+7.1_amd64.deb) ... Unpacking replacement php5-cli ... Hit http://security.debian.org wheezy/updates InReleaseng .../libphp5-emb Ign http://mirrors.kernel.org wheezy InRelease Hit http://security.debian.org wheezy/updates/main amd64 Packages Hit http://mirrors.kernel.org wheezy Release.gpg Hit http://mirrors.kernel.org wheezy Release Hit http://mirrors.kernel.org wheezy/main amd64 Packages Ign http://apt.readynas.com 6.4.0 InRelease Hit http://apt.readynas.com 6.4.0 Release.gpg Hit http://apt.readynas.com 6.4.0 Release Hit http://apt.readynas.com 6.4.0/updates amd64 Packages Hit http://apt.readynas.com 6.4.0/apps amd64 Packages Hit http://apt.readynas.com 6.4.0/main amd64 Packages Reading package lists... Done
I tried more than two times pydio installation through GUI and once through terminal
I got following error from terminaldpkg -i pydio_6.0.8_all.deb Selecting previously unselected package pydio. (Reading database ... 16261 files and directories currently installed.) Unpacking pydio (from pydio_6.0.8_all.deb) ... --2015-08-26 22:54:23-- http://www.dotdeb.org/dotdeb.gpg Resolving www.dotdeb.org (www.dotdeb.org)... 195.154.242.153 Connecting to www.dotdeb.org (www.dotdeb.org)|195.154.242.153|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 5299 (5.2K) [application/octet-stream] Saving to: ‘dotdeb.gpg’ dotdeb.gpg 100%[====================================>] 5.17K --.-KB/s in 0s 2015-08-26 22:54:23 (111 MB/s) - ‘dotdeb.gpg’ saved [5299/5299] OK dpkg: dependency problems prevent configuration of pydio: pydio depends on php5-pthreads; however: Package php5-pthreads is not installed. dpkg: error processing pydio (--install): dependency problems - leaving unconfigured Errors were encountered while processing: pydio root@RDNASOS6-X:/tmp# apt-get install php5-threads Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package php5-threads
At the end the pydio GUI just shows of the Readynas Installed app page andclicking on launch(http://192.168.2.41:7126/index.php) redirects me to
This webpage is not available
ERR_CONNECTION_REFUSEDanc clicking on Settings(https://192.168.2.41/apps/pydio/index.php)
redirects toNot FoundThe requested URL /apps/pydio/index.php was not found on this server.
Apache/2.2.31 (Debian) Server at 192.168.2.41 Port 443 Nothing works! How can I install php5-threads? - super_poussinAug 26, 2015Virtuoso
dpkg --info pydio_6.0.8_all.deb| /frontview/bin/fv-dpkginstall.awk -v allow_not_signed=1
- sunsinaAug 28, 2015Guide
root@RDNASOS6-X:/tmp# dpkg --info pydio_6.0.8_all.deb| /frontview/bin/fv-dpkginstall.awk -v allow_not_signed=1
new debian package, version 2.0.
size 15002072 bytes: control archive=125330 bytes.
36 bytes, 1 lines conffiles
478 bytes, 10 lines control
486820 bytes, 4675 lines md5sums
1757 bytes, 57 lines * postinst #!/bin/sh
1132 bytes, 38 lines * postrm #!/bin/sh
294 bytes, 18 lines * preinst #!/bin/sh
Package: pydio
Version: 6.0.8
Architecture: all
Maintainer: Netgear Inc <[email protected]>
Installed-Size: 33381
Depends: php5-gd (>= 5.6.4~), php5-mcrypt (>= 5.4.4), libapache2-mod-php5 (>= 5.4.0), php5-curl (>= 5.3~), php5-imap (>= 5.3~), php-pear (>= 5.3~), php5-pthreads, mysql-common (>= 5.5.28), php5-mysql (>= 5.4.4-13), mysql-server (>= 5.1), mysql-client (>= 5.5.0)
Found 11 dependants
pkg[1/11]= php5-gd >= 5.6.4~
pkg[2/11]= php5-mcrypt >= 5.4.4
pkg[3/11]= libapache2-mod-php5 >= 5.4.0
pkg[4/11]= php5-curl >= 5.3~
pkg[5/11]= php5-imap >= 5.3~
pkg[6/11]= php-pear >= 5.3~
pkg[7/11]= php5-pthreads
cmd=apt-get -y install php5-pthreads
Package php5-pthreads is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another sourceE: Package 'php5-pthreads' has no installation candidate
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
E: Can not write log (Is stdout a terminal?) - tcgetattr (25: Inappropriate ioctl for device)
failed!
Package nut-client is not configured yet.dpkg: error processing nut-server (--configure):
Package nut-client is not configured yet.dpkg: error processing nut (--configure):
Package nut is not configured yet.dpkg: error processing nut-snmp (--configure):
nut-client
nut-server
nut
nut-snmp
fv-dpkginstall.awk: error 3
fv-dpkginstall.awk: success - Retired_MemberSep 04, 2015
Hello,
I have the same issue, I followed the discussion tried what's on it, and I'm still unable to install Pydio 6.0.8 on a ReadyNAS 516 OS 6.2.4.
Any ideas?
In advance, thank you!
Best.
________________________
I have succesfully install php 5.6, but I still can't install Pydio
root@Grp-M_NAS:~# php --version PHP 5.6.12-1~dotdeb+7.1 (cli) (built: Aug 8 2015 01:28:25) Copyright (c) 1997-2015 The PHP Group Zend Engine v2.6.0, Copyright (c) 1998-2015 Zend Technologies with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2015, by Zend TechnologiesAlso as advertised, Owncloud is indeed not possible to install anymore
ok I found the solution :
nano /etc/apt/sources.list
add
deb http://packages.dotdeb.org wheezy-php56-zts all deb-src http://packages.dotdeb.org wheezy-php56-zts all
apt-get update
if you get an error like:
GPG error: http://packages.dotdeb.org wheezy-php56 Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E9C74FEEA2098A6E
then :
wget http://www.dotdeb.org/dotdeb.gpg apt-key add dotdeb.gpg
and again
apt-get update
then :
check you on PHP 5.6.x
php -v
if all's good restart apache:
service apache2 restart
and then try to install again Pydio 6.0.x from the GUI
Best!
- sunsinaSep 04, 2015Guide
Ok,
I tried first to remove the faulty packages nut, leafp2p
by running #apt-get remove --purge nut-server nut-client leafp2pThen I changed teh sources.list and applied #apt-get update
Then I got #php -v ---->
PHP 5.6.13-1~dotdeb+zts+7.1 (cli) (built: Sep 4 2015 17:39:30)
with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2015, by Zend TechnologiesSo it seems that the PHP is upgraded to version 5.6
BUT
I still have problem installing pydio 6.0.8 via GUI and via dpkg -i
In fact the problem now is the mysqladmin#dpkg -i pydio_6.0.8_all.deb ... ...... ....... OK mysqladmin: connect to server at 'localhost' failed error: 'Access denied for user 'root'@'localhost' (using password: NO)' dpkg: error processing pydio (--install): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: pydio
I am not sure how to fix this mysqladmin problem?
- Sep 04, 2015Retired_Member
