Sandshark
Jan 08, 2017Sensei
Anyone tried Let's Encrypt / Cerbot on the ReadyNAS (esp for Owncloud)?
I run OwnCloud on one NAS as a way of exchanging files with a small group. Some have a real problem with the lack of a "proper" SSL certificate. They are too virus paranoid to tell their browser to...
osilvab
Jan 08, 2017Aspirant
Im in the same situation trying to use my domain with a DDNS from no-ip.com to my owncoloud installed in the NAS 102.
I have installed cerbot following the instructions in
https://certbot.eff.org/#debianother-apache
the auto couldnt do it itself so i had to run the certonly mode.
m problem is that Cerbot i asking for my webroot directory. i do not have any idea what is it.
Sandshark
Jan 09, 2017Sensei
For OwnCloud, it's /c/apps/owncloud/web. I'm not sure if you need the leading /c or not. If you've created a website in a normal share, then it's /c/data/sharename. Basically, it's wherever the appropriate index.html is.
