Sandshark
Jan 08, 2017Sensei
Anyone tried Let's Encrypt / Cerbot on the ReadyNAS (esp for Owncloud)?
I run OwnCloud on one NAS as a way of exchanging files with a small group. Some have a real problem with the lack of a "proper" SSL certificate. They are too virus paranoid to tell their browser to...
osilvab
Jan 08, 2017Aspirant
I have also tried this:
but if I chose the standalone option i get an error that port 443 is running other service. even after stoping apache or killing it i can not liberate the 443 port.
still no succes with letsencrypt on the readynas.
Sandshark
Jan 09, 2017Sensei
osilvab wrote:I chose the standalone option i get an error that port 443 is running other service. even after stoping apache or killing it i can not liberate the 443 port.
Any tries with 6.6.0, since it's Jessie based?
lsof -i :443 returns the list of processes using port 443. On the system I use for experimentation and have ReadyCloud enabled on, one of the processes is leafp2p, which is the ReadyCloud VPN engine. There are also a couple others, as I have a lot of apps working on it. On a live system without ReadyCloud enabled and very few apps, only apache2 is using it (though supporting multiple PIDs).
- osilvabJan 09, 2017Aspirant
Sandshark wrote:
For OwnCloud, it's /c/apps/owncloud/web. I'm not sure if you need the leading /c or not. If you've created a website in a normal share, then it's /c/data/sharename. Basically, it's wherever the appropriate index.html is.
yes, I tried this but i got error in Cerbot, but it could have been because my apache seems not well configured now. see this threadIm afraid the Cerbot tries to work with the default apache folders and config files and overwrote somethings.
Sandshark wrote:Any tries with 6.6.0, since it's Jessie based?
Im on 6.6.0. I tried the Cerbot for Jessie but it didnt find the packages, like if the reporsitory is not there. that is why I followed the "Debian (Other)" instructions
when i had the error about the 443 port I used lsof -i. (btw the -i suffix is not working anymore) and netstat to find out what was working in the 443port. it was apache as expected and I killed manualy. then run again Cerbot and everything got worse. see this thread
- SandsharkJan 09, 2017Sensei
The instructions do say you need to add the backports repository to the sources list before it will install with apt-get. But given the problems you had, and the solutions you've tried, I doubt the auto install would work, anyway. I was concerned that the non-standard directory structure could cause an issue, and it looks like my concern was warranted.
I'm not really much of a Linux guy, anyway. I used Unix (and even Multics) quite a number of years ago, but I have to Google a lot for modern Linux usage. So, I doubt I'll have any better luck installing it. Thanks for the updates. Looks like I need another solution.
- osilvabJan 11, 2017Aspirant
I managed to ger the SSL certificate, please see this thread for more details
