Digital999
May 23, 2022Luminary
Backup soncurency question
We have multiple Netgear systems. Currently there are are a number of backup jobs defined for these systems and they typically occur at off-hours when there is no meaningful traffic. They seem to ru...
- May 24, 2022
Digital999 wrote:
If I have a NAS to NAS job running that takes a long time will any of the other backup jobs that are on timers actually run or will they be stalled waiting for the long job to finish?
The scheduled backups are also queued, so they would wouldn't run until the longer job(s) finish. If they are still running (or waiting to run) when the next scheduled time is reached, then you will get an error message (and the next backup will not be queued, so it won't run twice).
If your backups are incremental, then this might still be acceptable. The long backup times you are seeing now might not be typical.
FWIW, my own backups are all NAS-to-NAS, and are run off-hours. I use "pull" backups (running on the destination NAS), and those will can concurrently, since they are running on different machines.
One drawback of "pull" backups is that you can lose coherency. When you do a "push" backup (running on the source), the backup is actually being made from a temporary snapshot. If a file changes during the backup, then you are still guaranteed to get the file as it was at the start of the backup. But that can't be done with a "pull" backup.
One drawback of "push" backups is that it is difficult to put the destination NAS on a power schedule, since you don't know when the backups will end. That's the reason I use "pull".
Another thing you could do is create your own backup scripts for some of the jobs - either running them manually from ssh, or running them as cron jobs. You'd lose the integration with the web ui, so it'd be more difficult to manage them. But it is possible.
May 24, 2022Guru - Experienced User
- Sep 19, 2018Retired_Member
