WSJ
Jan 01, 2016Tutor
Baikal for ReadyNAS Duo (v1, Sparc)
I'm wondering whether anyone has managed / attempted to run Baikal on ReadyNAS Duo (Sparc). It's much lighter than OwnCloud and for me it would serve the main tasks: CalDAV and CardDAV. Currently I...
- Jul 28, 2017Finally I've got a ReadyNAS Pro 6 with OS 6.7.5 - and thus I'm able to use Baikal (aka "Contacts and Calendars Server" app).
BrianL2
Jan 02, 2016NETGEAR Employee Retired
Hi WSJ,
Welcome to the community!
ReadyNAS Duo (4.1.x) is already EOL. Having Baikal as an additional add-on is unlikely. If you want to check the add-ons related to SQL, calendar and etc. all of them are available here.
Let me know if you have other questions.
Kind regards,
BrianL
NETGEAR Community Team
- WSJJan 10, 2016Tutor
I'm not expecting Netgear to provide such an Add-On.
But I was asking the community whether anyone has such plans in mind - or can judge the feasibility.Since there's even an Owncloud Add-On, it should be technically feasible to support Baikal.
- StephenBJan 10, 2016Guru - Experienced User
WSJ wrote:
... or can judge the feasibility.
Perhaps reach out directly to WhoCares_ either via PM or at rnxtras.com. He can likely give you an accurate assessment very quickly.
- WhoCares_Jan 10, 2016Mentor
Actually, I had Baikal up and running once but can't remember on what ReadyNAS platform ;) I'll have a look but it should be doable even for Sparc based systems.
-Stefan
