WSJ
Jan 01, 2016Tutor
Baikal for ReadyNAS Duo (v1, Sparc)
I'm wondering whether anyone has managed / attempted to run Baikal on ReadyNAS Duo (Sparc). It's much lighter than OwnCloud and for me it would serve the main tasks: CalDAV and CardDAV. Currently I...
- Jul 28, 2017Finally I've got a ReadyNAS Pro 6 with OS 6.7.5 - and thus I'm able to use Baikal (aka "Contacts and Calendars Server" app).
WSJ
Oct 02, 2016Tutor
Since version 0.3.0 Baikal requires PHP 5.5
Latest version is 0.4.6.
Do you still intend to invest some time for freaks like me?
Actually I'm using ownCloud primarily for calDav, so Baikal would be the best choice for ReadyNAS Duo v1 (Sparc) since it's much more lightweight.
Or do you have some documents on how to build Add-Ons for ReadyNAS Duo v1?
I know that previously such was available, but I cannot find it anymore.
Cheers, Wolfgang
WSJ
Nov 20, 2016Tutor
Well, maybe Radicale would suit ReadyNAS Duo v1 even better - since it "does not depend on any library. It is known to work on Python 2.6, 2.7, 3.1, 3.2, 3.3, 3.4 and PyPy > 1.9" according to the "user documentation".
