Bolly2007
Feb 08, 2017Tutor
Bittorrent client suggestions
I've got RN104 and considering running a bittorrent client on it. What is the best current solution?
Bolly2007
Mar 18, 2017Tutor
Thanks again. I've tried the Transmission app. Works fine it does not support RSS feeds which is a deal breaker for me. Any suggestions?
FramerV
Mar 20, 2017NETGEAR Employee Retired
Hi Bolly2007,
Unfortunately those on that link are the available apps that we have. If none of them will work for you, you could wait for an app that will be published (3rd party). You can also probably message the app developer for the Transmission if there is anything that he can help you with.
